View graphs for OSPF on a VLAN. The graph formats available are: line chart, area chart, bar chart, and pie chart.
  • OSPF must be enabled.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Basic tab.
  4. Select a VLAN, and then select IP.
  5. Select the OSPF tab.
  6. Select Graph.
  7. Optional: To refresh the values in the table, select Clear Counters.
  8. To specify the polling interval, from the Poll Interval drop down menu, select a value. The options are:
    Choice Option
    Choice Description
    5s
    The polling interval is 5 seconds.
    10s
    The polling interval is 10 seconds.
    30s
    The polling interval is 30 seconds.
    1m
    The polling interval is 1 minute.
    5m
    The polling interval is 5 minutes.
    30m
    The polling interval is 30 minutes.
    1h
    The polling interval is 1 hour.
  9. Select one or two values.
    To select two values, for example, AbsoluteValue and Cumulative. Select the first value, and then press the Control key to select the second value. You cannot select more than two values.
  10. From the toolbar, select a chart icon. The options are:
    Choice Option
    Choice Description
    Line Chart
    Displays a line chart for the values you selected against the polling interval. The X axis represents time. The vertical axis represents the logging scale.
    Area Chart
    Displays an area chart for the values you selected against the polling interval. The X axis represents time. The vertical axis represents the logging scale.
    Bar Chart
    Displays a bar chart for the values you selected against the polling interval. The X axis represents time. The vertical axis represents the logging scale.
    Pie Chart
    Displays a pie chart for the values you selected against the polling interval.
    The Chart Legend uses different colors to identify the values you selected that are plotted on the graph.
  11. To switch the horizontal and vertical axes values, on the chart toolbar, select Horizontal.
  12. To switch views of the log scale from high to low values, or low to high values, on the chart toolbar, select Log Scale.
  13. To switch to another chart using the same values, on the chart toolbar, select a chart icon.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
Name
Description
AbsoluteValue
Displays the counter value.
Cumulative
Displays the total value since you opened the OSPF-Graph tab.
Average/sec
Displays the average value for each second.
Minimum/sec
Displays the minimum value for each second.
Maximum/sec
Displays the maximum value for each second.
LastVal/sec
Displays the last value for each second.
VersionMismatches
Displays the number version mismatches received by this interface.
AreaMismatches
Displays the number area mismatches received by this interface.
AuthTypeMismatches
Displays the number AuthType mismatches received by this interface.
AuthFailures
Displays the number Authentication failures.
NetMaskMismatches
Displays the number net mask mismatches received by this interface.
HelloIntervalMismatches
Displays the number hello interval mismatches received by this interface.
DeadIntervalMismatches
Displays the number dead interval mismatches received by this interface.
OptionMismatches
Displays the number options mismatches received by this interface.
RxHellos
Displays the number hello packets received by this interface.
RxDBDescrs
Displays the number database descriptor packets received by this interface.
RxLSUpdates
Displays the number Link state update packets received by this interface.
RxLSReqs
Displays the number Link state request packets received by this interface.
RxLSAcks
Displays the number Link state acknowledge packets received by this interface.
TxHellos
Displays the number hello packets transmitted by this interface.
TxDBDescrs
Displays the number database descriptor packets transmitted by this interface.
TxLSUpdates
Displays the number Link state update packets transmitted by this interface.
TxLSReqs
Displays the number Link state request packets transmitted by this interface.
TxLSAcks
Displays the number Link state acknowledge packets transmitted by this interface.
